well im going through the procedure of completly tearig down my aspire rear axle beam down to ever nut and bolt and rebuilding it. so far its all been tore down, sand plasted, por 15 the whole rear beam, new FMS trailing arm bushings installed. i had a few issues that i needed to fix, first off my passanger spindle the the threads where a little messed up so i had to get that fixed, then when putting on the new wheel cylinders the holes did not line up with the drum backing plate so i had to drill them a little bigger. i really didnt want to drill them but it seems theres only 2 supliers for the the wheel cylinders brakeware/bendix and tru torque, no one had any locally so i couldnt verify if i had a bad batch or thats just how they where. i reasemble the drums but i have a few extra pieces 4 springs and 2 horse shoe shaped clips, i know 2 of the springs where for the adjuster but i used the old ones. Also when installing the shoe hold downs and locking clip, the hole on the shoe is a little large so the spring has a tendancy to fall into the hole a little, it would be nicer if thy had some kind of washer underneath or something to prevent this. should i add a washer? or dont worry about it? heres some pics
