brake swap
  • brake swap
    I just have a GENERAL question, can I use the festiva brake line hoses on my new aspire hubs, or should I order some aspire hoses? Will the festiva ones work for now? Or totally incompatible?
    Also... BLAAA BLAA
    Logan
    You need the Aspire hoses. There is a little "prong" that goes into the back of the hub, which holds the hose in place... The Aspire one is shorter than the Festiva piece.
    If you look at the 2 pieces side by side, you'll see what I mean.
    Simon - pimptiva.com
      Can you use/re-use the Aspire upper strut mounts? Assuming they are from a lower mileage car and are in good condition of course.
      I assume the rear bushings are a direct swap. My Fest has 173k on it, and I am willing to re-use parts to save money, but not at the cost of safety.
      Also I noticed that local auto parts stores want upwards of a $55 core charge for Aspire calipers, so I suggest buying them at the yard, esp. if you are going to get rebuilt ones, and they only charge you $10.
      89 L
        The strut mounts, from what I've seen, are the same (I had Aspire springs on the Pimptiva while it was parked over the winter and they fit fine)
        $55/core charge for calipers? Switch to another store!
          I used Aspire strut mounts on my Mutt. They work fine, and if you get newer/lower mileage ones, may as well use them.
          Karl
            I have since added up "replacing" all the Festiva brake hardware, everything down to the bearings and even the spring kit for the drums, and it comes out well over $500, just as a ref. from Advance Auto.
            I know I should be able to get most everything off of an Aspire for under $300, so I plan to re-use as much as possible assuming its a lower mileage car and looks like its been maintained. I just hope that the one I find hasn't been hit too hard if at all for fear of buying bent susp parts. I am going to grab the Aspire struts, springs, upper mounts etc., just to have them in case I want to experiment with the springs. Plus it should make pulling it apart at the yard a lot faster.
            89 L
              napa is 55 dollars for the core as well.
                I stripped an Aspire today. Rear axle, including E-brake line, cut the soft lines at the chassis, also took the struts and springs. Off the front I got everything from the upper strut mount to the control arm. Couldn't get the friggin spindle off. Also picks up all 4 wheels(steel) and the spare.
                Probably get new rotors, try and re-use the calipers, maybe new hoses. Got go and get the sway bushings, and maybe upgrade to some GR-2 struts all around.
                On the rear, I thought I read something about using a specific rear rubber line on the right and another on the left? Are they both Festiva or is one an Aspire?
                I assume I can run 175/60/13 tires on the stock Aspire wheels?
                Thanks
                89 L
                  The 175/60-13s on the Aspire wheels has been done by several folks and no complaints noted.
                  Using Aspire brake hoses on the rear will work fine. I reused the old Aspire rear hoses on my first conversion. I got all 4 new Aspire hoses for my next one.
                  Karl
