rear strut bolts
  • rear strut bolts
    ok i am doing a aspire swap on my 88 and when i was removing the aspire rear beam the bottom strut bolts broke so how can i bolt the struts up? i have torched the old out with out hurting the beam but there is a small wall in the beam that stops from puting a new nut in and holding with a wrench to tighten any one have this prob be for? what should i do.
    If you mean the piece that is at the back, just cut it out, then the wrench will go in. If you want you can weld that back on, I didn't, and had no problems. Show a pic of the "wall" in question.
      ok this is the rest of the bolt i cut it and was going to cut the nut inside the beam so i could run a new bolt and nut but this wall is in the way its right after the nut on the inside for the strut.
      it is like this on both sides
        I put bolts and nuts when i re-did old red's suspension.
          i want to but can with that wall there in the beam bottom pic
            Knock the broken portion off (in) with a punch. Put a flare nut in a box end wrench and stick it in there. Run the bolt through the new strut....cake.
              look at the pic you cant get to the nut that is a spindel nut
                ok well this is a ? on the front i got every thing is all on but the break line the rubber one is so tight its like almost at a kink what should do or is this ok?
                  [ATTACH]2101[/ATTACH]
                    Are you using the festiva lines or aspire lines?
                      aspire the festiva ones wont fit
                        Ok, just making sure. I'm not around my car at the moment, so I can't really help, but I know for sure my brake lines on the swap don't look like that. Are you sure you have everything in the right spot?
                          yeah at first i thought it was the wrong side but i switched it and still same
                            Ok, well maybe someone else will be able to help, but next chance I get I'll see how it's set up on my other car
                              ok thanks for the help tho
