rear strut bolts
  • #16
    the flex line looks like it not installed right, its kinda hard to tell from the pic but i'd almost say you installed it upside down
    The hook thing i beleive is only meant to stop the flex line from twisting back and forth causing the bolt to loosen, so try spinning the flex line around where it feels like it wants to naturally sit
    • #17
      ok il see but i dont know haha
      • #18
        damkid hears pics
        • #19
          [ATTACH]2104[/ATTACH]
          [ATTACH]2105[/ATTACH]
          • #20
            [ATTACH]2106[/ATTACH]
            • #21
              This pic really shows its upside down for sure
              Are you sure you didn't put the calipers on the wrong sides? like the passenger side caliper on the drivers side??
              Thats what i would assume is going on there
              • #22
                i might have but i put them on the way i took them off the aspire haha they may have been on backwards when i got them il swap them and see if it fixes them thanks alot damkid
                • #23
                  ^^No prob, hopefully that'll fix it
                  • #24
                    me two then i have to see about doing the back but im in need of a drivers side rear strut to be ready for the rear beam
                    • #25
                      This would be the perfect time for new rear struts, that way you won't need to fight with getting the old rear struts off the festiva trailing arm
                      I wish i had installed new rear srtuts when i did my swap, would have shaved about 2.5 hours off doin the rear
                      • #26
                        I thought they were upside down too
                        • #27
                          haha i got one off but the other bolt broke and the sleeve that goes in the bottom rubber part of the strut for the bolt well it is stuck with the bolt on the old beam thats y i need a new strut or just another sleeve but i cant find any and i dont gots the money to get the new strut haha i hate having no money and owin alot to people or i would have my project done haha
                          • #28
                            ok they was on the wrong sides a well the front is all done but bleeding. now on the rear beam could i just cut a hole on the bottom to get a wrench in to hold the nut and then weld a patch over it??
                            • #29
                              ok i got it all done and one jsut have to bleed the breaks because i replaced all the lines.
                              • #30
                                broken bolt
                                I had the same problem. I cut those two brackets off the back with a cut off wheel to get more room to work. Then I used a torch and got the nut red hot and just blew it off with the o2. Mine came real easy. Then I just put a grtade 8 bolt through it with a lock washer. I wasnt sure how important those brackets were so I went ahead and welded them back on. I did this about 2months ago and have not had a problem since.
