For anyone who wants to upgrade their brakes, the V6 Mx3 booster is bolt on, and there is enough room to bring the clutch cable out the same hole. anyways the reason i went to this booster is for the hydraulic clutch conversion.
I mounted the entire Mx3 v6 clutch pedal assembly and clutch master cylinder... BARELY fit, but it fit.
where the clutch pedal sits isnt perfect, but its good enough. Had to trim all the brackets for the festy clutch pedal off the side of the bracket and reverse the pivot bolt so the end that stuck out for the old clutch pedal comes out the other side and its not in the way of the mx3 assembly.
Steve GT
