Well the manual Capri pedal assemblies are very close between the two, the bolt pattern for the Capri master cylinder is the same as where the cable bolts to the firewall. You may only need to drill the pedal arm and add an actuator rod. I have both pedal assemblies here if you really wanted I could pull them out and take pictures. I don't think the Festy bolt pattern is the same though, now that I think of it.
Theoretically you wouldn't have to really swap anything at all
