Look for wheels that are 14x6 with a 38mm offset. And stock bolt pattern is 4x114.3
whos running 14inch wheels
I really like the Metro 13" steelies for cheap rims and better tire availability. They have the Festy bolt pattern. To me, the best all-around tire size for Festivas is 175/70x13. I would run the Kumho Solis in that size; all-season, good in snow, 80K mile warranty, probably no rubbing (I haven't tried them on a Festy yet, in this size).Originally posted by number1_kid View Postcant find nothing that wont rub seem to me
dont matter Ill stay with the 12inch wheels if its such a hassle or problem90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
those are pretty nice rims.....will have to save my pennies till I grow up.Originally posted by 25Horseplay View PostAll you have to do is search. Here is a nice set with dual bolt patterns.
http://cgi.ebay.com/ebaymotors/4-NEW...Q5fAccessories"FLTG4LIFE" @FINALLEVEL , "PBH"
185/60/14 Rims
185/60/14 on Jetta rims, in the picture I am trying to show you there is a complete set of Drums and lighting gear inside.
Cannot copy and paste picture?Aspires and Sways all around, Miata B6 installed, KYB G2Rs just installed in front. Wish for coil overs someday.
I've done some searching, so sorry if I didn't search deep enough.
I couldn't quite find an answer to this:
Can I use the stock lug bolts with non-Festiva rims? Such as metro steelies or any 14" rims? Or would I need to install studs? If so, what size studs and how do you do that?
I'm a newbie at Festiva tires/rims, so sorry if this is basic common knowledge to y'all.~Austin
Red 88 L (Ocho)
195-60-14.... mine dont rub, but i have verry stiff springs. ive also ran 205-60-14 with no problems.
88 festiva lx, 2.3 turbo rwd swap in progress
1999.5 f-350 4x4 7.3 gtp38r 5" exhaust ect.
R.i.p. 1990 Western Star 5964s 3406b 530whp (4.2mpg!)
00' western star flat top ex, 600hp 6nz 2250tq, 18918b, 3.55, full lockers, 6" straight pipes
03' gt, full termi swap 700+ whp build
sponsered by,
pam pam's junk, dayton OR.
Bob's ok tires, salem OR.
Clausen Truckin', keizer OR.
I can't edit my last post...
I found the write up on installing studs.
I've been looking at 14" rims/tires on CL.
To confirm:
185-60/R14 would be 5-7" rim width. The offset calculator says 2mm more on 5", 11mm less on 6" and 24mm less on 7". I assume this means that I would have to install a spacer between the hub and wheel to clear suspension components if the rims were wider than 5"?~Austin
Red 88 L (Ocho)
I've got 185/60x14 on 6" wide AR Estrellas, dual bolt pattern. No rubbing becuase I have Aspire rear struts.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
you can use the festy bolts, if there are a minimum of 6 threads protruding past the mating surface of the rim.Originally posted by Oren09 View PostI've done some searching, so sorry if I didn't search deep enough.
you can't use honda rims unless you use VW bolts because honda rims don't have a conical seat for the bolt head.Trees aren't kind to me...
Right, I found out the hard way that my stock lug bolts didn't work on my aftermarket aluminum wheels. Vibration at hwy speeds. Ended up buying aftermarket lug bolts, which had a longer conical area to grab the thicker wheel. The other option was of course studs.
Stock lug bolts work fine for Metro steelies, which are as thin as our wheels.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
