I'm putting together Bolt Kits for our suspension components - After searching for the replacement bolts (or lack there of) through parts stores I have resulted to using Fastenal - I have sourced all the required bolts accept for the bolts that hold the rear beam on.
If someone can get me some measurements of these bolts it would be greatly appreciated.
I've circled the bolts I still need confirmation on. They are the Strut attaching bolts, The Torsion beam bracket bolts and the torsion beam pivot bolts. These are all for the rear - I have confirmation on the front.
I need the measurements like the following below - the Bolt shown is the front strut to hub mounting bolts (M12x55 with thread pitch of 1.5)
Also I need to know if the nut is flanged and if it is a suraded locking nut attached is not.
