does anyone know what, if any 14''wheels will fit an 88 festiva, i need to be able to get speed rated tires, thanks
14'' wheels
1973 Cb750 haven't touched it yet with no idea what I am planning on doing with it
1978 25th Anniversary edition Corvette
1983 Chevy Elcamino
1993 Ford Festiva GL
2003 Hyundia Santa Fe ( Wifes Daily driver)
some old dodge motorhome I have no idea of the year
I have 14"x6", 38m offset American Racing Estrellas on Casper. These are dual-bolt pattern: 4x114 for Festys and 4x100 for Aspires and lotsa other cars.Originally posted by festiva351w View Postdoes anyone know what, if any 14''wheels will fit an 88 festiva, i need to be able to get speed rated tires, thanks
Normally you will need spacers for the rear, but if you go with Aspire rear struts, which have a higher spring perch at the bottom of the spring, you might not need them. The fronts will be fine.
You might need to use a hammer to compress the inner fender lip on all four fenders; and maybe pull the fenders out a little, by hand.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Oh, my tires are 185/60x14, BTW. Relatively minor rubbing issues until I "massaged" the fenders a bit to fix it.Last edited by TominMO; 01-03-2010, 10:24 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
well ok thanks, i have a pro/street festiva tubbed out, with rear wheel drive and mickey thompon 29x18.50 on it, so yeah i need speed rated tires i blew out a 12'' @104 mph, so i want to get bigger wheels so i can get hp tires for it, on the front, well i was hoping that someone could just say that wheel of whatever make/model will fit, auto part stores seem to be only able to look up parts for an exact vehicle, no cross referncing, your in put has haepled, thanks
You need to host the pictures somewhere. Photobucket works great, you can host them there then just paste the IMG link on the site.Originally posted by festiva351w View Postyes i have pics i dunno how to put them on here
To answer your question Nissan Altima wheels will fit.
-Greg
Redneck Engineer
FOTY - '09
