Hi,
I just put some 185/60/13 tires on my 13" wheels.They rub on tight right turns.I also put some 195/45/15 on my 15" wheels.The front cleared without a problem.I did had to run spacers on the rear,I don't know the size of the spacer i'm using.I looks like they clear now.The problem was,That the tire sat on the rear strut.It was'nt much the car rolled but you could hear the tires rubbing.I'm going to drive around right now.I should get you the spacer size if some of you need it.Here are some pictures of the festiva.
