Those parts look better than what you can buy at the parts houses. That's a job very well done!
Aspire brake swap
Originally posted by Festiva_Fred View PostDid you clean up/repaint the aspire rear beam also? Nice work btw.
Oh yeah, of course. The brakes are just easier to work on off the beam. Probably close to a $500 swap labor not included. Maybe a little less.Last edited by freshtiva; 03-20-2010, 06:37 PM.sigpic
No Aspire is 4x100, Festiva is 4x114.3, the advantage is bigger brakes, front and back. And most of the time it is easier and cheaper to find 13" tires then it is to find 12".Originally posted by ShagFestiva View Postare the rears on aspires the same lug pattern as stock festy's? Is it a worthwhile upgrade?'90 LX
Awesome job Marcus! The only thing I can see missing is braided stainless brake lines.Originally posted by freshtiva View PostMore pics
Ian
are these the only parts needed for a aspire swap? i dont know much about this stuff. if pictures could be provided of what i need it would help me get there. my brakes are starting to get bad, alot of vibrating when hard braking, pulling when braking etc. i dont want to replace the festy parts i want to do the swap.
^^Those, the Aspire rear beam and E-brake cable, and the Aspire outer tie rod ends, I believe.
For your reading enjoyment.
Fresh, those are so, so sexy. You definitely take your time and do it right. Nice work. :thumbright:
1989 L - 247K miles Slick
dont forget the front sway bar...
Mike, AKA the sasquatch
the sway bar is a choice, not necessary for the brake swapOriginally posted by sasquatch View Postdont forget the front sway bar...
just for clarification for newer members
^ right, but if you can get one i would highly recomend it... if you own a 5 speed car it should fit no problem... if you have a "F" or "G" trans in your car your motor mount may be in the way... and if you have a auto trans in your car it may be a PITA to fit... i had trouble fitting one and just gave up...
Originally posted by fastivaca View PostAwesome job Marcus! The only thing I can see missing is braided stainless brake lines.
Yeah, braided brake lines. drool Good idea !!
Thank you, its the result of cabin fever from this winter.sigpic
