you're supposed to use festiva LCA's with the aspire swap. Did you use festiva or aspire struts/springs? If you used aspire that would raise the front and probably make it handle worse than before. Put the aspire front swaybar on too! You'll love it!
my frist big mod
no i keep the festiva struts and spring. i feel like i have lest trac. all it wants to do is spin like it driving on the out side of the tireOriginally posted by Festiva_Fred View Postyou're supposed to use festiva LCA's with the aspire swap. Did you use festiva or aspire struts/springs? If you used aspire that would raise the front and probably make it handle worse than before. Put the aspire front swaybar on too! You'll love it!
i plan on the sway bar swap. i was just reading up on it now lol .the heart beat of america stops here______________/\
\/\_____________FORD
FOREVER
You probly got your camber off when you remounted your hubs
they make camber bolts if you can't get it with in specs with out them
check too see if you have a steep angle at where the hub mounts to the strut
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
ok i will look in to that thanks.Originally posted by Festiva_tunner View PostYou probly got your camber off when you remounted your hubs
where could i go to get a camber kit and does it have to before a honda to fit a festiva.the heart beat of america stops here______________/\
FOREVER
I heard, don't know if it is true but I did hear it from the only alignment guy I trust, that if your camber is off, removing the top 2 nuts and spinning the strut around, can help in the camber department. Actually you would be turning the "bearing", the rubber top of the strut 180 degrees. Would be an easy thing to do and might help.ENFORCER - Midwest Festiva Inc., Iowa
#2 .....Cheesehead
#3 '91 White - Donor Car
#4 .....Montana Project
SOLD----Levistiva for $1500
Bought her back for $450
i've heard that too, but only on some cars..Originally posted by Levitan View PostI heard, don't know if it is true but I did hear it from the only alignment guy I trust, that if your camber is off, removing the top 2 nuts and spinning the strut around, can help in the camber department. Actually you would be turning the "bearing", the rubber top of the strut 180 degrees. Would be an easy thing to do and might help.
-Aspire brake swap COMPLETE!
This is true, my camber was off after doing the swap, and after doing this it fixed it.Originally posted by Levitan View PostI heard, don't know if it is true but I did hear it from the only alignment guy I trust, that if your camber is off, removing the top 2 nuts and spinning the strut around, can help in the camber department. Actually you would be turning the "bearing", the rubber top of the strut 180 degrees. Would be an easy thing to do and might help.-93' L BP swap/e-series, coilovers, RIO front swap, redrilled festy drums, Miata 14" 7 spokes.
-85' Nissan Sentra 5 spd.
ok tryed to take the rear axle out of the festiva but it has been fighting me the whole way so it is still up in the air waiting to get done.
oooh ya found out why the festiva was handleing so bad.
i thought the aspire tie rods ends got swap when i put it back together but it was still the festivas ones. i will order some aspire one on monday.
anyway my white festiva will not b ready for race day tomorrow so i ame going to fix my green and take it to the races.the heart beat of america stops here______________/\
FOREVER
well after 11 hours i finally got the swap done i think the car looks much better with the 13 on it haha for now.
next thing on the list is to get some coilover so i can lower and stiffen it up for thr races i will keep u postedthe heart beat of america stops here______________/\
FOREVER
Congrats on finishing the swap!!
