can you use the aspire lower control arms on a festiva, along with the aspire brake swap?
Aspire LCA?
I Have the entire aspire suspension on my festy including the lca's. I havent had any problems yet, I did need chamber bolts though because of extreme neg. camber. It still appears to have some, but I have only done a self alignment and it seems to handle good and will prolly do better with computer alighnment. I have only used one set of camber bolts but if it needs more adjustment I will just get another set for the bottom holes. My setup makes lifted my festy but for i like the way it looks and it is alot more practical than lowering for me, due to the roads and country drivin I do. Btw I have the b6de swap with f trans. and regular 323 cv's.91' "Maztiva" my $400 Festy, with 96 B6DE/F25MR MX-3, and Aspire swap
96' Exploder
72' dodge Tradesman 200 "The Van"
96' MX-3 - donor
91' Festiva - parts
alright? got some mixed answers here, im doing the aspire brake swap and putting in a b6t, i also would like to put in come tein coil overs, so would like the car pretty low. some people say the aspire lca fit on the festy, but would it be practical with the set-up i want?
I had a thread going about aspire axles and they said no to both the axles and the control arms. Still no definate answer? Not saying you do not have them on your car angrygocart, but other members who have done swaps just say it doesn't work. Since I have more aspire parts left over than festiva stuff, it would be nice to use some of it, as aspire odds and ends don't have the same type of resale value.1993 GL 5 speed
With all of the research that I did, your safest bet would be to go with Festiva LCA's. Less risk that way. Good luck on the swap, I will be doing mine in the next week or two.
Poverty produces creativity
