Today I went out and weighed several tire/wheel combos, just out of curiosity. All the tires have good tread, so wear would be a minimal factor. Weights are with a bathroom scale. I weighed each tire three times to try to get consistency; averaged the weights and rounded up to the next pound, to allow for some wear.
TIRE SIZE......WHEEL SIZE*...WEIGHT...WHEEL WEIGHT
155/80x12.....12x4.5 S..........23..........11 (estimate)
155/80x13.....13x4.5 S..........26..........12
185/70x13.....13x5.5 A..........25..........10
185/60x14.....14x6.0 A..........30..........13
*S=steel, A=aluminum
I was surprised to see that there was only a 7-pound difference between the 12" steelie and the 14" aluminum tire/wheel! And that the aluminum 13" was lighter than the steel 13" with a narrower tire. The aluminum wheels are much thicker for strength, but even so aluminum wheels are still pretty light; more than I had expected. The 14" is my AR Estrella on Kittystiva; the 13" aluminum is the older AR (from Casper) now on the Aspire.
To get the wheel weights, I looked up what these tires weigh on Tire Rack, and subtracted tire weight from overall weight. Probably a good estimate. Couldn't find a weight for the 12" tho.
I also have a set of 13x4.5 aluminum factory Aspire rims. I didn't weigh one of them because the tires are bald, so it wouldn't have been such a good comparison. But I may anyway, and add it to this list.
If you want to add to it yourself with other sizes, feel free to cut and paste this list and add on to it.
Or to put it another way, you're too short for your weight.
