BTW if the idea here is to save weight and use skinny tires as part of a high-MPG car, a 155/60x15 tire is about the same diameter (22.3") as a 155/80x13 (22.8"). I find it hard to believe that the 15x4 rim will be significantly lighter than a 13x5 rim. Using the 15x4 makes sense to me if used with a really tall tire, like my 165/80x15s (which are presently mounted on heavy steel spacesavers). That would give you taller gearing for the hwy, with no significant increase in weight.
Tire/wheel weights
Never mind. Answered my own question.
Last edited by sketchman; 07-04-2013, 11:32 AM.Any difference that makes no difference is no difference.
These are a 1 or 2 year only rx7 spare wheel, they are made by Enkei in Japan and stamped MAZDA. It's common for high end cars and sports cars to have nice alloy space savers. These are pretty rare (still waiting for my 4th wheel to come along). They aren't super light even though they are only 4" wide. I had planned on building a MPG festiva, but now I'll probably just use these on my Festy trailer. I have 3 so that's perfect for a trailer and it'll be nice to have the same bolt pattern on the car and trailer.
I believe the original Minilites were magnesium.
I also think I've read that real magnesium wheels need more careful handling and checking to make sure they're safe, and they may have more issues with losing air pressure if they're not sealed properly.
Oh, and the cost... !
Charlie, I'm waiting for you to weigh those alloy space savers, with or without the tires on them.
KarlLast edited by Safety Guy; 07-05-2013, 09:56 AM.'93GL "Prettystiva" ticking B3 and 5 speed, backup DD; full swaps in spring!
I read quite a bit of Mikey's links and there are pretty good arguments given that rolling resistance was less using some wider profile tires. Still trying to get a mental grip on that, makes me want to tow a car around with fishing scales and measure different tires actual rolling resistance. This engineer was saying that at speed the easier rolling wider tire easily beat out the aero advantage of a narrow tire. If the tires are behind a good dam then aero wouldn't matter anyway. I keep thinking "yes but nothing beats a good bicycle tire" and they are really tall and narrow, also rounded tread.Reflex paint by Langeman...Lifted...Tow Rig
I've got one of these in my garage. PM me an offer and I'll see what shipping costs. Plus, that means we'll have a weight finally!Originally posted by Advancedynamix View PostThese are a 1 or 2 year only rx7 spare wheel, they are made by Enkei in Japan and stamped MAZDA. It's common for high end cars and sports cars to have nice alloy space savers. These are pretty rare (still waiting for my 4th wheel to come along).
