Ya know it's not the rim, size it's the tire size. I'll bet you can get real close to the OD of the tires I'm running on 15" rims in a 17" low pro design. ( which is 22.5") The problem you'll probably run into tho is width. I'd run 17's with 1.5" of rubber all the way around..... because I like the look.( As long as it's lowered)
Found these......215/35/17 - 22.9" Overall Diameter; 2.2" SideWall
