Man.. what a difference.. mine were pretty shot and all this talk about ball joint failure coaxed me into finally installing the new set I bought awhile back.
New control arm goodness
Damn right!
This is probably the most worrisome part of a Festiva to me. I took the Mutt into two shops to get my ball joints checked (as well as the whole front end) for looseness. They said they couldn't find anything wrong!
Soon thereafter I got fed up with the weird movement in my front suspension and I jacked it up and found...TWO BAD BALL JOINTS!! :evil:
My advice to everyone is to learn to check them yourself!!
KarlJim DeAngelis
kittens give Morbo gas!!
^^ Too funny , With all this talk I too am going to check mine, I know what you mean Karl , I have thought about it and it scares me too , I do have a shimmy and when they done my tranny he said they were a little loose , the ball joints,and know I feel it when I accel and between shifts it's like the front end is sliding up and down on a sleeved shaft,I am sure that is the excess play I am feeling :bounce:------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
Originally posted by sk8er_Guy03lol, I thought I had a bad ball joint too, felt like my right side suspension was going to fall out!!! Checked it and it was just a loose bolt (one that hold the control arm in, lol), acutally it almost fell out, but i did have bad ball joints too! heh heh
Regards,
TimWhite '89L auto - Sold!
Silver '06 Rav4, 95k!
Originally posted by the_big_1.3i hade mine pop out on me .... i put the jack under the controll arm and ligned up the ball and snaped i in place..... it got me home and fell out again
Regards,
Mine came apart on my driveway last week (luckily). I knew there was play in it since the summer, but only recently heard clunking noises.BP powered 91 Festiva L
-FMS springs, GR2 struts, Toyo T1R 195/45/14 on Swift GT alloys
-Trunk mounted gel battery
-Suzuki Swift GT seats, Grant GT steering wheel, auto-locks
-Blaupunkt Melbourne deck with Bluetooth, sealed single 12" sub
Hear clunking noises that aren't the CVs?
See or feel play in your ball joints?
Going through a curve and the car steers a bit more when you haven't moved the wheel?
Don't be shy and don't be late! Time to change 'em out!!
:?: never checked mine, at least one of the bj's is the original (1988 L , 4-speed, 170,000 miles).
Can someone tell me how to check them?? And, if I have to get them replaced, how much is it ? Traveling across country late March, don't want to have an accident!!
Thanks!
