if its possible to drill, tap and stud aspire drums for a 4.5" bolt pattern? I'd love me some real rear brakes but dont want two different bolt patterns...
Does anybody know...
I'm sure you could take them to a machine shop and have it done. may have to weld more material in there on the backside.89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
Originally posted by bhazard View Postif its possible to drill, tap and stud aspire drums for a 4.5" bolt pattern? I'd love me some real rear brakes but dont want two different bolt patterns...
You just wanna run Falcon wheels don't you....Yup, I know your plan..LOL
you could use GLC rear brakes...?Trees aren't kind to me...
My swap is done with a drilled out festy beam and aspire hubs mounted.89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
My site: 20tessa.sytes.net
Really I have no idea. It seemed easier to do it this way. A couple good drill bits and a few hours of time and bam the rear can be swapped. Drilling the holes out can be a pain if you dont have a good sharp drill bit.Last edited by 91_festy_Gl; 09-09-2010, 09:55 AM.89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
Originally posted by bhazard View PostYou mean spindles? So whats the difference between that and just throwing an aspire beam in?plus you get the added benefit of the big fat torsion bar-ish beam that runs the length of the Aspire axle to help stiffen the rear end
The Aspire unit bolts right up, the only reason I could see not to use it would be if it was damaged or if you just flat out didn't have it, just had the spindles.
No festiva for me ATM...
Originally posted by htchbck View PostIf you use the Aspire beam there is no drilling requiredplus you get the added benefit of the big fat torsion bar-ish beam that runs the length of the Aspire axle to help stiffen the rear end
1988 Chevy Sprint Turbo 997cc
^^^ wasn't meaning to knock the use of a Festiva beam, I had to drill one to accept Aspire spindles once myself when the Aspire I got my spindles off of was wrecked and the axle was bent. My statement above was more directed at the idea that redrilling a Festiva beam was easier than using the Aspire beam, which in my opinion if you have the Aspire beam, its much easier to install everything as a unit rather than remove and redrillNo festiva for me ATM...
