Ok so I done the aspire swap with protege front calipers. Once I was done with the swap I moved the car to wash it and it had alittle brake. I knew I was suppost to bleen the system but i wanted to wash it first so anyhow I moved the car and it stopped slowly and then all of a sudden the pedal hit the floor. Me and 3 other people have bled the crap out of the system and still no pressure builds up.
I replaced the rear brake lines, master, portion valve, and still nothing. The master has been bench bled numerous times. The booster checks out fine. After 25 bucks worth of brake fluid nothing has changed. I have no idea what else to do besides take it to a brake shop. Do you guys have any insight on this? The car has been down 5 days because of this problem.
There is absolutely no leaks anywhere. Does the brake pedal rod need adjusted? My ebrake works great.
