First I know the lug pattern, which I've read from DJ's sticky, Wil's site, 3 other posts in this forum + if I weren't lazy I'd take a measuring tape and figure it out.
This may be fundamental to you guys, but I don't know what the 40 mm offset means and if it's important. Does it mean if I get wheels that have a zero offset the wheel base will be 80 mm wider or 80 mm narrower.
If I want to run a 155/70 R12 tire, would I be better off with a 4.5" wide wheel, would it still fit on the 4" wide?
Also, is it possible to upgrade to 13" gradually, two wheels at a time with the 13" on the back and 12" on the front?
Thanks guys
Thanks guys
