Come on guys lets break into the 11s
  • #16
    ya i know that... but is it longer from the bolt that gose in to the frame of the car to the ball joint of the hub? also cause its from a diffrent car it COULD have diffrent mounting points.... it may fit, but the arm may sit in a weird place cause the mounting spots in the 323 where diffrent from the festiva, and it may put the hub forward or back in the wheel well, and that would also change your caster of your suspension...
    Mike, AKA the sasquatch
    • #17
      it seemed just as long as the festiva control arm, the guy who did it didnt do a side by side picture, the weels look like there in the same spot, even though the wheel wells are cut its still appears to be centered
      • #18
        hrmmmm, i may have to pick up some 323 arms now... damn you hot wheels, making me spend all my money by giving me all these crazy ideas... :p
        • #19
          I don't race my Festy but I agree the slop in the suspension is part of the problem, but have you tried toeing out the alignment? When the engine torques the halfshafts, the front edges of the tires are going to turn inwards more than everyday driving. Also, there is camber to consider. The front of the car is going to lift up, thus changing the wheel camber. I would try a little toe-out & a little negative camber.
          That's my 2-cents worth.
          - Kirk
          • #20
            Originally posted by grocerygetter View Post
            I was cutting 1.9-1.85 60fts with my car and all i had were urethane sway bar bushings preloaded like crazy with washers.
            I don't think that is what is keeping us out of the 11's....i'd break a tranny past 60 ft everytime......those damn diffs are the weak point.
            what i would do for a 1.9 60 ft.....
            • #21
              My SR car has lower a arms... I try to take a pic for next week.
              • #22
                i got to thinking on traction bar ideas... heres what i brainstormed... bare with my horrible drawings... it seemed simplest and with the least amount of fabrication... you might even be able to get away with bolting the car side bracket to the frame rail...
                • #23
                  ^^i think your on to something there
                  • #24
                    Originally posted by sasquatch View Post
                    are the 323 arms any longer that the festiva ones? or dose it place the hub further forward or back in the wheel well?
                    I grabbed a bg control arm last week. Its about a inch longer than a festiva one.
                    Ill try to remember to crawl under one of my bfs this weekend and measure it.
                    Better Than Nothing Racing
                    Way too many cars
                    :woc:
                    • #25
                      Big nasty slicks would do alot for a festiva IMO. Problem is fitting those under the front.
                      I did a 1.48 60' in my mustang (4 cyl.) last friday. All on a M/T ET drag. 26.0/8.5/15
                      -Greg
                      Redneck Engineer
                      FOTY - '09
                      • #26
                        something that may give you a slight insight as to what needs to be corrected watch in this video, during the pull, as they let off watch closely to the wheel in relation to the fender. http://www.youtube.com/watch?v=ogHfsnnt2cc hope this little bit helps.
                        Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
                        Dennis
                        93 GL In progress BP/hydro G
                        15 Mitsubishi Mirage daily
                        88 Dakota tow pig
                        • #27
                          i bet... like spit the diff outta the case
                          • #28
                            Originally posted by Damkid View Post
                            Before i try any crazy ideas for traction bars etc. i'll be getting an Mfactory diff :evil4:
                            Power Rating: ~1000whp :p
                            I like seeing the ideas in this thread. This is imo the biggest problem with Festivas. It's much easier to steal a solution than to come up with my own. hahaha
                            • #29
                              Finally crawled under my hatch and measured. The bf control arm is longer too. It looks like itll place the hub about a inch further out and slightly forward.
                              Way too many cars
                              :woc:
                              • #30
                                I wonder what that V-8 festy runs... Anybody know that guy?
                                1990 White L-Plus 5-speed rust-machine
                                Scrapped
                                1991 Blue L 5-speed
                                daily driver, intermittent project
                                1993 rustless wonder
                                A shell, awaiting suspension, brakes, and B6T
