These are off an '88 Mazda so should fit a Festiva with stock brakes.
Ian
I'm not positive, but I believe all the 323 had the same bolt pattern as the Aspire (4x100mm). The best way to find out is to ask the guy what the bolt pattern is on the wheels. Many small FWD cars have the 4x100mm bolt pattern, but the festiva has the much less common 4x114.3mm pattern. If those are 4x114.3mm, then you are good to go with the stock festiva setup, but if they are 4x100mm you'll have to do the brake swap first. BTW, those rims look sweet, use them if ya can.
