The aspire brake swap is completed.
Brakes are bled......E-brake is adjusted.
But it is obvious from the front of the car that the camber is way off.
The bottom of the tire is about a inch in compared to the top of the tire.
Its the same on both sides....in at the bottom...out at the top.
I used the festy control arms and sway bar.
What was replaced was the struts and hubs.
Is this because the struts are new and haven't settled yet ?
Did I install something wrong ?
Its supposed to go in for a front end alignment.....but this looks like a different issue.
any help is appreciated.
