this looks interesting
  • this looks interesting
    how much stiffer is this festy suspension? :
    Probably alot I'm about to do tie in that same point, LCA mount to mount, seems like a serious weakness of the Festy body... -Kyle
    Cosmic Blue 2008 Mazdaspeed 3 - Mostly Stock...
    White 1990 Ford Festiva - B6 SOHC powered 50 shot = 14.5 @ 94 mph Gone but not forgotten
    Proud member of Chicken Mechanix Racing
      We can manufacture some nice ones if we get 5 or more ppl.
      Thanks :wink:
        I'd be up for one if the price is right.
        The Festiva Store
          count me in..
            I bought 1" .095" thick pipe to make the brace out of and some 3/16" plate steel for the actual end pieces... I will be making the brace tomorrow. I'll post pics when completed and probably make a short how-to... -Kyle
              Tim Deronne has been using that on his road racing Festiva for years!
              * Retired Festiva-er*
              1990 Festiva - The Once Fastest Red 1990 Festiva LX on this site! - now in more dedicated hands!
              B6T'ing since May 2002...
              Disclaimer: I'm a dick, deal with it.
                Ill start a list for lower Brace: If you want one pm me and all add your name.
                The first questions what is the max you would pay for one. Say if it was a very nice peice. Tig welded perfect fit powder coated Black silver blue etc.
                More ppl better quality material and lower price will go.
                I can save weight and make it super strong. can do even carbon fiber or titanium but what you guys want to pay will determine materials.
                Thanks
                  Very interesting........ I like
                    Would aluminum work well as a material?
                    What about galvanic reactions between different metals if it were aluminum? Would a very thin "gasket" protect the joint?
                    I'm worried about two things:
                    -hitting something with this low bar that might mess up the LCA bolts or mounts
                    -the thickness of the bolt mounting plates: would we/should we use slightly longer LCA pivot bolts for this, or does it matter?
                    I'm definitely interested in putting one of these on my future "Speedstiva."
                    I'd pay maybe $70 to $90 for a powdercoated one? Cheaper for steel, a little more for aluminum.
                    Karl
                      No problem with aluminum, I would suggest best material, chromoly as its strong and only has to be half the thickness of steal to have the same strength.
                      Let me know, I will work out a deal if some more ppl are interested.
                      Thanks :wink:
                        Count me in for one, I'll pay the price for a near perfect one :wink:
                        Is that a Festiva that just passed me?!?!?!
                          Ok well I just finished mine, right now it's not "pretty" but tomorrow once I sand it down again and paint it, it will look awesome and it fits perfectly.
                          For me the idea was to make a brace that connects the 2 U rails that run the length of the car and finally end at the LCA mounting points. I did NOT actually use the LCA mounts to mount mine. My brace will be 2 inches behind that so I will not need to get a longer bolt and essentially does the same thing. The brace is TIG welded and is very very strong. Also since I am going to be drilling through both sides of the U channels, I made some spacers for inside the "U" so that when I tighten the nut and bolt down the U channel will not be destroyed. Now if there is interest in my piece I can produce them this summer (May-June) they would be made out of mild steel as mine was for $30-40+shipping with an arrangement of colors (although I am not flashy so I will be painting mine flat black) which will include the brace just as mine is along with all the hardware necessary to install it. -Kyle
                          Here are the pics of it:
                            I'll get the final pictures of it installed tomorrow once it's all set to go on..
                              Ok, I finished painting and bought the rest of the hardware. The pictures are up on the link... Let me know what you think. -Kyle
