Is there any suspension differences between the 2 and 4 door aspires? And the hubs have the same spline count between manual and auto right?
Aspire differences
Never messed with the suspension much, but Napa doesn't show different struts (front or back) between the 2 and 4 doors, all seem to use the same struts. As for the hubs, yes, they are the same. The only difference is the rotors and calipers. I bought the whole front assemblies off an auto Aspire once and about 3 years later finally got around to installing them but by that time the bearings were toast because they were sitting in the carport and water got in them so I didn't use them. I pulled everything off the auto hubs and picked up a good pair of manual hubs from the jy. Auto rotors and calipers bolted right up to manual hubs, no issues.No festiva for me ATM...
BTW, I can tell you firsthand that the 2000 & 2001 Kia front struts, springs & strut mounts are similar as well. I just installed a set into an Aspire with no modifications necessary.Originally posted by ShagFestiva View PostIs there any suspension differences between the 2 and 4 door aspires?
Besides the obvious differences, the only main difference I know of between 2 and 4 door Aspires would be the gas tanks. The 2 door is the same unit used in FI Festivas while the four door tank won't work.
Does anyone know if the e brake cables are the same between 2 and 4 door Aspires? I would guess they are the same, but I'm not sure.
I might be able to measure the e-brake cables on both. I'm guessing something in it would have to be longer because of the extended wheelbase.Originally posted by Safety Guy View PostBesides the obvious differences, the only main difference I know of between 2 and 4 door Aspires would be the gas tanks. The 2 door is the same unit used in FI Festivas while the four door tank won't work.
Karl
Also, the 2-doors all had manual steering, while 4-doors could come with power steering. But that really is the only other major thing that I know of under the car.
I think my 1995 2-door Aspire SE has P/S; I'll check tmw.Originally posted by Aspire View PostI might be able to measure the e-brake cables on both. I'm guessing something in it would have to be longer because of the extended wheelbase.
Also, the 2-doors all had manual steering, while 4-doors could come with power steering. But that really is the only other major thing that I know of under the car.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
The 4 door automatics have stiffer springs than the 2 door manual or 4 door manual.
88 festiva lx, 2.3 turbo rwd swap in progress
1999.5 f-350 4x4 7.3 gtp38r 5" exhaust ect.
R.i.p. 1990 Western Star 5964s 3406b 530whp (4.2mpg!)
00' western star flat top ex, 600hp 6nz 2250tq, 18918b, 3.55, full lockers, 6" straight pipes
03' gt, full termi swap 700+ whp build
sponsered by,
pam pam's junk, dayton OR.
Bob's ok tires, salem OR.
Clausen Truckin', keizer OR.
Oops, nope I don't have P/S.Originally posted by TominMO View PostI think my 1995 2-door Aspire SE has P/S; I'll check tmw.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by ericsmith32 View PostAll of my 2 door Aspire haven't had PS. My current 97 does and is very nice to have!
Yeah, they don't put the PS in the 2 doors & when the strut mounts start to get old it takes a lot of muscle to turn the wheel.
That's why I installed the Kia strut mounts; they have roller bearings instead of bushings...at slow speeds, I can whip the car around with a lot less effort.
Aspire wrote:
"I just put the 2-door & 4-door emergency brake cables together...if anyone cares...the 4-door is about an inch longer & has a different type of mounting system for routing next to the gas tank."
Thanks Aspire! Good to know.
