coil over kit cheap and modify?
    I bought these.
    Pic of the night I got them.
    I am using the stock festy top hats and they work fine.
    93L sold. First FESTY!
    93GL Sold Too Soon!
      ^^^ Are they pretty stiff??
      88 Festy L (The White Thunder)
      91 L came and gone, owned only 2 days
        ^^^ They are a little bouncy, But NOT stiff...
        The bounceing is ok, If it was "jarring" stiff, I might not have liked them.
        Compared to stock=WAY better!
        Compared to "real" coilovers=WAY cheaper, lol
        93GL Sold Too Soon!
          the EXACT reasons why i got mine
          Mike, AKA the sasquatch
            I'll second that. they are bouncy but not stiff at all. we went over some train tracks and my spine is still intact.
            I'll be picking up a set myself
            Previous:
            1991 GL. (01' ranger lights!) P/S,A/C Sold to Mum.
            1990 auto. hacked up rally toy.
            1988 5 speed. The pile
            1993 5 speed.
            1995 5 speed aspire. Gutted for the 90' auto.
              I'm buying some tomorrow. You convinced me
                ^HaHa! Cheap ebay coilovers FTW!!!!!
                93GL Sold Too Soon!
                  That and I'm tired of the festy dragging its hind quarters around on the ground with all the tools I have in it.
                  Previous:
                  1993 5 speed.
                  • #24
                    i have cheap ebay hoda coil overs on the front of my car and they are a bit stiff but not terrible...
                    I know its a piece of crap but im still faster...and its 100% legal!!!!!
                    • #25
                      I bought crx springs and if they are adjusted up all the way they are on the bumps. I got coils from a @quare body accord or civic I cannot remember what model. Look for a kit with long adjusters so u can compensate if they are too short. The crx kit I bought had really short adjusters and that was part of the problem. I believe the springs I have now are about 7-9" long.
                      88 festiva lx, 2.3 turbo rwd swap in progress
                      1999.5 f-350 4x4 7.3 gtp38r 5" exhaust ect.
                      R.i.p. 1990 Western Star 5964s 3406b 530whp (4.2mpg!)
                      00' western star flat top ex, 600hp 6nz 2250tq, 18918b, 3.55, full lockers, 6" straight pipes
                      03' gt, full termi swap 700+ whp build
                      sponsered by,
                      pam pam's junk, dayton OR.
                      Bob's ok tires, salem OR.
                      Clausen Truckin', keizer OR.
                      • #26
                        Do I have to modify anything to get them to fit?
                        • #27
                          that looks GREAT!
                          -Aspire brake swap COMPLETE!
                          • #28
                            I will take a few pix in a few to show u exactly what I did.
                            Also, NO... There is no mods to get them to work.
                            Basicly Remove old springs,
                            Put sleeve on strut, then put spring over sleeve, then
                            install original tophat from festy, then reinstall everything.
                            On the rears, switch the top washer (the one inside hatch)
                            with the one on the underside(looks like a cup)
                            Reinstall and your done.
                            By doing this, it will give the rear a inch higher postion(Simply find a flat washer for the inside cupped looking one and your even)
                            93GL Sold Too Soon!
                            • #29
                              Originally posted by ejp2fast View Post
                              that looks great!
                              thanks!^^^
                              93GL Sold Too Soon!
                              • #30
                                U can cut the old spring perches off of the coils if u decide you are gunna run them. If u cut them off then u can run way wider tires in the front and not worry too much about the offset bc you won't have the perch in the way anymore, but you will still hit the "frame" if you crank it hard. I have a set of 10" wide slicks I gotta mount up one of these days.... fronts and rears for autox. But I will just use them for the drags most likley.
                                sponsered by,
