Question. what do you think. and will they fit. =]
Get it ready for the drive to Ohiostiva.
What Matt said! 8)
Here's a link to the proper thread on Ohiostiva:
Show up at Classic Minis at 10am and even if you don't want to cruise with us to PA, you can get in an hour or so of socializing.Saturday, May 20, 2006
Moraine State Park, PA
Meet up at the park between 1 and 2 pm.
Ohio contingent meets up at Classic Minis in Tallmadge between 10 and 11 am. We'll move out around 11 am for Moraine.
They might work, I have 13x7 reverse 80 spoke, you need to make sure you have correct adapters for the bolt patern. With 175x50x15 they should fit, in extremely sharp turns they may rub a bit. Im running 155x80x13's on my 13x7 wires and they work fine. With a reverse rim you need to make sure the shocks in the back are good, because under a load they will rub the fenders. Also with a reverse rim you need to pack those bearings, they take alot of abuse with a reverse rim. Pay close attention to wheel alignment too, cause those tires will peel in a hurry if you're not careful. I think those wheels might fit and clear the brake calipers, mine clear ok at 13x7. I would like to see some more spoked Festiva's out there. I would reccomend a 13x7 on 175x50x13's tire if you like the "spokes look."
With those adapters you should clear ok, I even had some bolt on Roadsters that worked out ok too with a universal 4 bolt pattern, you can pick those up pretty cheap these days and you can put wheel locks on em so noone will jack em on you. Take care my friend and good luck on the decision. Joe
P.S. I never knew about a 13x5.5 spoke rim, good price for em though at what they are asking.
In my avitar here you can see what they look like, however I have a modified airride suspension and in the pic the car is in pancake and thats why they are so close to the fenders.
