Are You Running 195/45/15?
  • Are You Running 195/45/15?
    If you are please let me know if you are happy or not. Why or why not? And what mods you had to make from stock to run them.
    12 and 13 are becoming difficult to find and 14S are too expensive. Thanks
    '93 Festiva GL / "HOT ROD"
    '02 F-150 Supercrew
    '02 Excursion 4x4
    '98 Jeep Cherokee Classic Limited
    Running 195/60-15 for the winter then ill be back to 195/50's...
    91GL BP/F3A with boost
      195/50/15's fit fine and are alot cheaper and eaiser to find than 195/45/15's...
      Mike, AKA the sasquatch
        The 14s I've been looking at are all in the $40-$50 range
          I got a set of 15's with 195/50-15 tires you can run on your car and see how you like them
          Stock engine shouldnt be bad, Just with my BP and bad struts I didnt like them.
          On tire rack they are as cheap as 12" tires.
          pix of them on the festy... With aspire springs you shouldnt have any rubs....
          93L sold. First FESTY!
          93GL Sold Too Soon!
            Ive found 195/45 Nexen tires in the $50-$60 range which is close and id like to keep my speedo as acurate as possible. Im assuming if you guys are running the 50 series your not having any brake problems.
            Geativa, i may take you up on that offer but i will probably need to talk with you more about the springs. Thanks
            '02 F-150 Supercrew
            '02 Excursion 4x4
              I ran 45's for about a year. No real difference in the tires I was on stock suspension. Now I'm on fms with 50 series and it rubs inner fender well on hard turns.
              1989 Ford Mustang GT 5.slow
              1996 Ford F-150
                I ran 195/45-15 on 15x6.5 wheels with +38mm offset and didn't do any mods to car, no spacers of any kind, and they NEVER rubbed in any condition. I will try to find a pic and post it for ya. The best part about them is they are super near total stock diameter so your speedo will not hardly change.
                -Bryant
                  Since the Proxes 195/45-14s are just about ideal, and the 15s are the same size plus one half inch radius, you're looking at about 12mm taller than stock. This is on paper, of course, and it might not be an exact figure. But it's a smaller diameter than running 175/70-13s or 185/60-14s.
                  I think the main worry on 195/45-15s would be the wheel width and offset. If it's too extreme either way, you'll need mods to fit it.
                    195/45-14 is nearly exactly the same size under stock as a 195/45-15 is over stock. Super small amount. 6.5" width with +38mm offset fits perfectly. Really, I've done it.
                    But like Safetyguy said go any wider or change offset any and you will be toast.
                    My car ran for almost a solid year and there were absolutely no rub marks on the tires or the car. a 195/50-15 is only 4 7/8mm taller on each side or approx 1/8" on each side.
                    -Bryant
                      I would love to see pics Gomez. Where did you find your wheels?
                      '02 F-150 Supercrew
                      '02 Excursion 4x4
                        In john's(sedat's) thread for his car, If you take the front springs off your car and put them on your rear you gain right at a inch and 1/4 (cant exactly remember)
                        but we placed the tire next to the car and I bounced on the bumper and it was high enough not to rub/scrape.
                        With the fronts, swapping to aspire/kia rio springs(keep your struts) the front will be lifted enough to have no problems.
                        Stock springs can be run in the front with no spacers(hard dips rub) but rolling the (lip) of your fender will solve that....
                        In the rear stock springs can be run too with the spacers I have(will need the longer studs) and again, hard dips cause a lil rubbing, but rolling just the lip of the fender.
                        will PM you my number.
                        93GL Sold Too Soon!
                          Looks like the start of a Donk car. How much ground clearance is that?
                            i have 195/45/14's and love 'em!
                            -Aspire brake swap COMPLETE!
