I finally got around to doing the 2nd side of my control arm bushing on myfestiva. I did not find out you need 2 until later. I got the moog for the control arms and decided to do the Energy Suspention ones for the sway bar to frame. I got the ones with the brackets and Zerk fittings. I cut the bushings to size on the bench sander and drilled and tapped my brackets for the zerks. I reused my festiva ones as it was stated, they are much stronger.
Noticable difference.
I suggest before you do stiffer springs and a strut bar you do this 1st. Then go from there. So far I did the FMS springs, KYB K2 struts and the sway bar bushings and the Home Depot/ lowes threaded rod sway bar.
