Doing the aspire swap as I'm typing this and I can't get my tie rod ends off so I compared them to the aspire ones and there exactly the same???? I thought they were different
Please help fast
Please help fast
1991 blue L, 5 speed.
1988 red L-plus-all stock.Tags: None
There is a raised ridge on one side of the tie rod end. Whack that with a hammer.Originally posted by 91mcnasty View PostDoing the aspire swap as I'm typing this and I can't get my tie rod ends off so I compared them to the aspire ones and there exactly the same???? I thought they were different90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I used the stock Festiva ones and they seem fine. What serious problem could it cause?1992 white L, Bp, American racing 13's, stock trans.
I'm not sure what problems could arise, but have the shop swap tie rod ends to your Aspire ones when you get your alignment done. Temporary use of the Festiva ends to get you to the shop should be okay.
"Taper is different" is all I know.
Haha I never let shops Touch my cars. They always mess something up i got my alignment almost perfect so I think I'll leave it alone. And hopefully I don't die soon I wanna enjoy the aspire swap some more.
Result of using Festy tie rod ends????? If so they'll be changed asap1992 white L, Bp, American racing 13's, stock trans.
I understand1992 white L, Bp, American racing 13's, stock trans.
