Please help fast
  • Please help fast
    Doing the aspire swap as I'm typing this and I can't get my tie rod ends off so I compared them to the aspire ones and there exactly the same???? I thought they were different
    1991 blue L, 5 speed.
    1988 red L-plus-all stock.
    not same
    the taper that goes into the steering knuckle is different. Ever so slightly, but is different. It won't seat properly and could cause serious problems
      There is a raised ridge on one side of the tie rod end. Whack that with a hammer.
        I used the stock Festiva ones and they seem fine. What serious problem could it cause?
          I'm not sure what problems could arise, but have the shop swap tie rod ends to your Aspire ones when you get your alignment done. Temporary use of the Festiva ends to get you to the shop should be okay.
          "Taper is different" is all I know.
            Catastrophic failure leading to certain death, that's what. lol.
              Haha I never let shops Touch my cars. They always mess something up i got my alignment almost perfect so I think I'll leave it alone. And hopefully I don't die soon I wanna enjoy the aspire swap some more.
                You gonna race that thing?
                  Result of using Festy tie rod ends????? If so they'll be changed asap
                    taper
                    The main problem is the different taper. You obviously want that to match the aspire knuckles. Otherwise you will have play and on festy front end, well not good. In extreme situation may develope high speed wobble. Yes you can bolt them in but they won't be tight in the knuckle.
                      I understand
