Wheel stud fitment
Wheel stud fitment
1991 blue L, 5 speed.
1988 red L-plus-all stock.Tags: None
I'll be buying them in like thirty minutes, can somebody help me out please!!!!1992 white L, Bp, American racing 13's, stock trans.
Yup, they'll work. I found the write-up on the conversion here: http://www.fordfestiva.com/forums/showthread.php?t=30758
2" length works out to about 51mm so no prob there.
Lug seat matches what was posted. Fire away!91 L 5sp "The Silver Bullet" B6, Brake/Susp Swapped Build Thread
92 L 5sp "Red" RIP
95 Grand Prix SE DD
Wife's Stuff:
89 L 5sp "Carby Car"
97 Aspire auto "Pink Panther" Build Thread
Spring 2013 IndyStiva:
http://www.fordfestiva.com/forums/sh...eet-April-20th
I used that thread to find those studs and nuts!!! Thanks thou
Kaleb1992 white L, Bp, American racing 13's, stock trans.
I'll let you know how it goes.1992 white L, Bp, American racing 13's, stock trans.
I would definantely recommend these. Installation on all four hubs only took about twenty minutes, and man does it make your wheels easy to get on!!!! My only complaint is that all the studs were just slightly bent, not enough to cause problems but just thought I should throw it out there.1992 white L, Bp, American racing 13's, stock trans.
I don't understand what your asking, but they threaded in quite easily I did not force them so I assume there seated properly. And they weren't bent an excessive amount, just ever so slightly, I could only tell if I threaded them in really quickly.1992 white L, Bp, American racing 13's, stock trans.
