Strut Mounts
  • Strut Mounts
    I Have just replaced the Struts and springs and my front mounts are in dire need of replacement.
    Brand suggestions?
    Previous owner of ZEFstiva
    fms high durometer.
      KIA Rio. They use a ball bearing instead of plastic disks
      Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
      Dennis
      93 GL In progress BP/hydro G
      15 Mitsubishi Mirage daily
      88 Dakota tow pig
        Are those a direct swap?
          Yep. No mods at all.
          Dennis
          88 Dakota tow pig
            So they will fit over my GR2s?
            What year?
              I just installed the kia rio struts from an 02 last month, and i havent had to use 2 hands on the wheel yet, not even moving slow in parking lots. Best thing to happen to a standard with no power steering since power steering. This way is quite a bit cheaper tho. The handling is alot better and my car doesnt lean anymore!
              That i know of, any year from 00-02 will definately work, its the same part #'s
              2008 Kia Rio- new beater
              1993 Festiva- Fiona, DD
              1997 Aspire- Babyspire, DD
              1994 Aspire - Project Kiazord
              1994 Aspire- Crustyspire, RIP
                I ordered Festiva struts and Kia Rio strut mounts and the two won't work together. The hole in the Rio strut mounts are too big for the Festiva strut rod.
                Ian
                  You can make a adapter if you have a lathe. Just need a a small steel rod and some time.
                    I was doing my coilovers last night and realized the spring perches on the festy are wider where it sits on the strut mount. Like everyone else said, you would need an adapter (basically a specialty washer) to use festy upper perches with rio upper mounts.
