ok so after breading ejp2fast's post about how much to cut from front and rear then reading the EvilD's "so i lowered the matchbox"s" problems i became confused do i cut 3" off front then 2.5" from rear or 3" from rear and 2.5 from front? im actually cutting them 1/2" shorter like EvilD but i want to to it right
Evil D if you get this how much did you cut from the rear and how much did you cut from fronts in order to acheive the lower in rear look? and did you ever cut more off fronts? if so how much?
