im confused evil d please respond
  • im confused evil d please respond
    ok so after breading ejp2fast's post about how much to cut from front and rear then reading the EvilD's "so i lowered the matchbox"s" problems i became confused do i cut 3" off front then 2.5" from rear or 3" from rear and 2.5 from front? im actually cutting them 1/2" shorter like EvilD but i want to to it right
    Evil D if you get this how much did you cut from the rear and how much did you cut from fronts in order to acheive the lower in rear look? and did you ever cut more off fronts? if so how much?
    Well, a couple things here:
    1) You may want to add your location to your profile, there may be someone almost next door to you that can help. Where are you located?
    2) The springs come off quite easily. You can try cutting a coil, re-installing them and seeing how it looks. If you are wanting it slammed, probably cutting 2 coils is a good start.
    3)You can also private message (PM) evil d directly and asking him. Just click on his name in the avatar and you will get a drop down window with options, one being "send a PM to evil d".
    Dan
      i tried pming and got nothing my question now is do i cut more from the rear or more from the front?
        Cut more from the rear.
        1990 White L-Plus 5-speed rust-machine
        Scrapped
        1991 Blue L 5-speed
        daily driver, intermittent project
        1993 rustless wonder
        A shell, awaiting suspension, brakes, and B6T
          I just say get lowering springs, cutting stock springs makes for a terrible performing setup.... but if it performs terrible, you could always blame your friend for the screw up
            It may take a few days for him to log on.
              Do it once do it right period.
              -M3NTAL MARK! Woo!!
