Which promotes better handling front or rear strut bar?
  • Which promotes better handling front or rear strut bar?
    I have a strut tower brace laying around here and I was about to connect it to the front strut tower.
    But then I seen a thread about someone making a rear shock tower brace, so Im wondering which promotes better handling in terms of reducing understeer.
    I have a piece of 5/8 all thread that I plan on using for the rear. If I had to guess I'd say the front needs all the re-inforcement it can get being that it's a unibody ? Does that mean sense? Lol
    How can I add a poll to this ?
    -M3NTAL MARK! Woo!!
    Understeer is the problem with festivas. I have owned festis with both and I think the rear bar helped more than the front.
    Just my opinion tho
    -Greg
    Redneck Engineer
    FOTY - '09
      Thanks for the reply Greg.
      -M3NTAL MARK! Woo!!
        The rear strut towers are not torsional areas, when it comes to corners, all the force from the reae axle is transfered through the pivot points. So a rear strut tower bar, really only adds overall body rigidity more than direct tower bracing.
        Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
        Dennis
        93 GL In progress BP/hydro G
        15 Mitsubishi Mirage daily
        88 Dakota tow pig
          if you get an adjustable miata bar it will work with minimal modification up front.
          Facebook Me!
            I'm pretty sure I heard Probe strut bar is a direct fit other than drilling a hole
            Previous owner of ZEFstiva
              A rear bar will make the rear end more responsive. Which will reduce understeer and make it easier to oversteer by easing off the gas in a turn. I just put one in this week and I'm pleased with the outcome.
                Ok I just put a rear one on.
                -M3NTAL MARK! Woo!!
                  are you kidding me???? You cut that really nice plastic??? :nono:
                    Come on willie theres tons of FL plastics around , i can really tell it reduces the understeer.
                    -M3NTAL MARK! Woo!!
                      I have not seen plastic in that good of shape except for a couple of times....and you just go and cut holes in it....sheeeesh! You must be mental or something!
                        M3ntal, i would recomend stiffer rear springs if not already installed.... much more stability during the turn than with the stock springs.
                          I'm running FMS Springs and Kybs on all 4s I can really tell the difference with that bar, can't wait to install the all thread under the rear beam!
                          -M3NTAL MARK! Woo!!
                            Here's a couple pictures of the bar we built for my car. The horizontal cross bar will be a triangle when finished and have mounting point on the floor as well.
                              i mean stiffer than that... i have FMS springs in Scrappy and when i added my helper springs, the rear became MUCH more responsive and the car was more willing to rotate (lateraly, not from sway).
