has anyone else had trouble after doing the aspire brake swap with regard to the control arms/ball joints loose in the aspire spindles. The only thing I can think of is rust on the spindle has caused the pinch mount to increase in diameter? I have tried 2 different sets of brand new control arms and both are very loose and the car doesn't handle well.
trouble with front aspire spindles?
It may be that the inside dia. taper on the spindles is worn.But its odd that you are having trouble with both sides. Is it possible someone might have damaged the taper dia when removing the ball joint from spindle?If it was severly rusted,they might have tried spreading the split area on the spindle with a chisel.Instead of using a a press/puller to remove ball joint. Other than that I'm at a loss for ideas.Anyone else?Originally posted by eastcoast413 View Posthas anyone else had trouble after doing the aspire brake swap with regard to the control arms/ball joints loose in the aspire spindles. The only thing I can think of is rust on the spindle has caused the pinch mount to increase in diameter? I have tried 2 different sets of brand new control arms and both are very loose and the car doesn't handle well.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Hubs = front
Spindles = rear'93 Blue 5spd 230K(down for clutch and overall maintanence)
Make sure you have the correct pinch bolts. Take the bolt out and hold it against the knuckle where the bolt goes through. Make sure the bolt has threads far enough down to allow the bolt to clamp tight on the ball joint. If you have a bolt that doesn't have enough threads to get it tight, when you run out of threads it will feel like you have it tight when it's not.You gonna race that thing?
I may be wrong, it happens often. But dont festivas and aspires have different tapers on the lower control arm?
ie; festiva lca fits festiva hub. Aspire lca fits aspire hub?
If true that could be cause for ill-fitment.
can anyone verify this?60% of the time it works, every time!
Nope, at least not on any I've dealt with. I've used Aspires hubs on several festivas, all using brand new festiva LCAs. Now the tie rod ends... thats another story. What outer tie rod ends are you using?
edit: haha me and blu posted the same thing at the same time
Take a hammer and pound the pinch bolt area together. I bet someone used a chisel on them to spread the area apart to remove the ball joint.89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
Whoops meant Knuckles,it was late.Originally posted by Pu241 View PostHubs = front
Spindles = rearSome people like to read fiction,I prefer to read repair manuals. Weird I know-
I think John has something here. The bolt might be shanked out.I use new bolts with washers on both sides.And a metal lock nut,not a nylon one.Dont forget to use LOTS of anti-seize when reassembling.Originally posted by Festy46 View PostMake sure you have the correct pinch bolts. Take the bolt out and hold it against the knuckle where the bolt goes through. Make sure the bolt has threads far enough down to allow the bolt to clamp tight on the ball joint. If you have a bolt that doesn't have enough threads to get it tight, when you run out of threads it will feel like you have it tight when it's not.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
