you mean on the pm's? If so, that happens from time to time. It passes. We are working on the issue. (slowly)
ATV Festiva
I like it but it is bad Juju here, the wolf part. We that live here and love the outdoors believe that the forest and wildlife should be managed for the health of the whole, too political...Originally posted by rockin86ranger View PostWolfstiva?
So how much you planning on lifting it? I know more than 3inches takes a lot of work on most front wheel drive cars, but 2-3" with the taller tires should do wonders.
Yes, I am shooting for 3", maybe more with cv and ball joint mods later.Reflex paint by Langeman...Lifted...Tow Rig
looks like you got it all updated..."FLTG4LIFE" @FINALLEVEL , "PBH"
Not bad have to think about that oneOriginally posted by rockin86ranger View PostSomething you might think about is a little bit of a spacer on the subframe,it will gain you some room for the tires to flex but it may require some reinforcing to be safe to drive on the street.
The space problem is the struts, The golf struts with the coilover kit should give me enough room. Rather than control arm inner mount drops I would probably build new control arms, for clearance.
So how about Flexstiva, i think it sounds good and flex refers to the offroading aspectReflex paint by Langeman...Lifted...Tow Rig
If it does I can rotate the rear mount down a little. I haven't looked into Porsche or offroad cv shafts but there might be some possibilities there.
I keep rethinking the coilover spring... front, 650 lbs and 4 inches of compression
( 3 loading the strut and one more when the car sits on it) .96 mechanical advantage factor. The nearest higher spring rate is 175 lb, that is pretty high compared to estimates of what stock is from our site.
The rear at 450 lbs , same preload and compression, same .96 factor works out to 110 lbs, but often I have the trailer, 115 lbs ?? I want to get this order off tomorrow..Reflex paint by Langeman...Lifted...Tow Rig
Spring rates deffinately aren't my specialty, have you considered doing a slightly lower spring rate in the rear and then adding air shocks or helper bags. Then you'll have better flex/ride empty and be able to haul a trailer.
Of course it's front wheel drive so who cares how the back flexs, just drag it lol. So i think i would go for the best riding spring that works best for towing. Might be able to save a few dollars on the back springs and just lower the spring pocket/strut tower, or use a spacer.
If concept proves out I will figure out a air ride suspension, long travel cv,Originally posted by rockin86ranger View PostSpring rates deffinately aren't my specialty, have you considered doing a slightly lower spring rate in the rear and then adding air shocks or helper bags. Then you'll have better flex/ride empty and be able to haul a trailer.
and heim joint lower a arm. No sway bar.Reflex paint by Langeman...Lifted...Tow Rig
Now I keep thinking about what you [B]didn't[B] say!Originally posted by Grey Vw View Post650lb and there won't be any compression lol
I just ordered 125 lb instead of the 175 lb
and rear I got 80 lb instead of 110 lb
It should still be a good lift, the springs
will be compressed 3 inches to mount and the
car will compress 2 1/2 inches more. With the coil over
I can always go up 3 inches or down another inch.
Parts will be here Monday.Reflex paint by Langeman...Lifted...Tow Rig
SKID PLATE!
I had a Festiva set up for rally. It had a 1/4" plate of aluminum that went from a bar between the tow hooks back to about the front of the cat. Protected the oil pan, trans, downpipe.
(It had some long coilovers, they did fine, something like 250 lb/in in the front and 150 in the back. Just had some tall 13" rally tires. Ground clearance wasn't really an issue with the skidplate. It did well in Colorado one summer, but really lacked power/gearing at altitude to do steep climbs. There's probably pics in some archive somewhere.)
Here it is a few owners before me: http://www.comicozzie.com/gallery2/v...96-03.jpg.htmlLast edited by tderonne; 12-28-2011, 12:44 AM.
