Originally posted by littlecar
What is on the shaft is torqued tight, cannot move, contrary to what you
suggest above. The shim or spacer will adjust the preload on the roller
bearing part...but it has to be measured correctly to get preload. Preload
can be verified by measuring the total rotating torque.
If you have shaft movement in and out of the knuckle itself your adjustment
is incredibly far off, like something left out.
