tire size?
  • tire size?
    im thinking about going with a 13" tire on a stock 323 steel wheel with a stock festy setup. my question is should i go with a 155 80 13 or 175 60 13 or is there a better choice? whats the pros & cons of the different sizes tks in advance danny
    I'd go with the 175 in either a 70 or if available, 60 series.I'm running 175-70-13 on my silver 90.
    My original 13's were 155-80's I like the 70's due to being slightly shorter and wider
    Jerry
    Team Lightning
    Owner of Team Lightning
    93 L Lightning. BP
      I love my 155/80s on Green Car, but the 175/70s on chuck are more stable. If you can find the 175/60s for a good deal that should be a great size to run
      No festiva for me ATM...
        tks j & j !
          I have 175/70's on 323 steels , they ride good. Everyone tells me 165/65's are better, but I can't find any around here at a desent price.
          '93 Green L - ' Tiva
            +1 on 175/60 for stability/handling, or 175/70 for the better ride. Either is better than 155/80. 175/60-13 is somewhat limited in selection. Tire Rack doesn't list any at all.
            Here is a 175/60x13: http://www.onlinetires.com/products/...1+77h+bsw.html
              tks
                For a really good 175/70-13 all season, I'd strongly recommend this Kumho Solus KR-21: http://www.kumhousa.com/tire/categor...2-F117F7942A2D
                They do everything well and last forever.
                  Not to hijack the thread, but i think it relates to the subject.
                  How much leeway does one have generally with the width size? for example jumping from 155 to 175 seems like a lot
                  ADMIN @ http://ironjuggernauts.com/forum.php?referrerid=1
                    Tread width and fit depends on at least four things:
                    -tire height (aspect ratio) consider this first, or your width comparisons mean nothing
                    -wheel offset
                    -if your car is lowered
                    -if you have Festiva spec or Aspire spec rear struts
                    There are more factors, but I think these are primary.
                    As for 175/60-13s, here is what Tires-easy has right now:
                    Plenty of Falkens left, but their price keeps going up. I like mine when I had them on the front for a few weeks. Switched to all snows now and will mount all Falkens around the end of March.
                    And for 165/65-13:
                    Funny, these split the difference between 175/70 and 175/60:
                    I've always had good service from Tires-easy every one of my three orders in the past two years.
                      I'd still recommend the Kumhos. Known good-quality tires and much higher treadwear value (640).
                        Tom could be right. I'm liking the 175/70-13 size a bit more myself these days.
                          I've got these tires in 185/70x13 on my Aspire and love 'em. I don't try to drive them as sport-car tires, since that size does not permit that. These same Kumhos in 185/60x14 on my Festy are driven much more aggressively. I've put a bunch of miles on them in 2+ years and they still look great.
                            Not a bad price per tire, but $110 to ship a set of four? OUCH! lol.
                              Okay, building on what Tom has said about the Solus KR21, check these out:
                              175/70-13 Solus and ecoSolus:
                              And the 165/70-13 Solus, sized better IMO and cheaper to boot:
                              Compare prices, mileage, number of tires available, and again, IMO the 165/70-13 will fit on a Festiva better than the 175/70-13, especially if you are running 5" wide rims.
                              Consider getting five or six tires just in case one of them gets a non-pluggable hole (it happened to me with one of my expensive Nokian all season snows!). One can serve as a spare and be rotated in, while six would be perfect for replacing the fronts when they wear down too much.
                              Finally, check out Tires-easy shipping quotes. Around $50 for a set of four of the 165/70-13s to me. I've found their shipping to always be reasonable, and quick too.
