Anybody know about VW golf struts,more lift?
  • Anybody know about VW golf struts,more lift?
    Are there any type struts anyone knows of that work and provide more lift and maybe more travel than the 3/4" lift of the rio struts? What about vw golf struts?
    The rio ball bearing upper mounting plates are awesome!
      what are those
      I see the pics what can you tell me about em and how much $$ does it cost.
        The 92 golf struts are under $60 bucks each, and sometimes you can
        get buy 3 get one free for monroe.
        The upper mount kits were around $30 for the front and $15 for the back.
        I couldn't find new rear spring cushions but two new dog chew toys are
        really tough and only $6 bucks each.
        I bought 2 new bearing retainers for the front, 20mm and 2 big truck
        lift kit washers...1/4" thick and almost 4 inches outside diameter. $10
        I bought a new civic 4 inch lowering kit for under $50 on ebay,
        I cut the spring seats off the front, I used the orings in the kit to
        center the coil overs on the struts, I roughed up the paint on the struts
        I used body panel glue from the body shop to glue these in place.
        I bought for springs from AFCO out of their garage sale, $30 each,
        and did not use the honda lowering springs.
        Discuss improvements to your Festiva or Aspire in the handling, braking, wheels and tires areas.
          You didn't have to redrill the top hole in the VW front struts, right?
          Because you are going with a high lift and didn't need to. Anyone wanting normal height, or lowering, would have to drill new holes. Am I right?
