My car isn't setup for smooth tracks. In fact I hammer washboard dirt roads quite regularly with both my Festy and my Capri which has the IRS you speak of. The festiva absorbs bumps much better. I spent a good portion of my teens and early 20s building rally cars and the MK2 VW was a FWD force to be reckoned with. Now the FWD rally weapon here in the states is the fiesta, which also has a trailing beam. A trailing beam is independent, like I explained before, and its natural arc is one that follows the ground better than a multilink. Look at the off-road world to see trailing link/trailing arm/ swing arm and swing axle designs that are congruent with a trailing beam. The festiva is nearly flawless in this aspect. It is like A lighter and more rigid MK2 VW, but it's also shorter and therefore much much faster around corners. The Chase car on my " the hills have roads" video was a 2.0 turbo swapped mk2 that was set up and driven by Chris Duplessis' (Ford sponsored rally America driver) mechanic Brandon, and he slid off the road several times trying to keep up. I wasn't pushing the festiva at all. That same video shows how well these cars handle on rough roads and dirt. I jump my cars regularly and haul loads that exceed what the factory intended. The little festiva is a miracle of automotive design just the way it is.
Again Tom, I think there are a lot of members with the same questions, so thank you for asking. I will go into more detail when I continue my " festiva advantage" write up.
