Originally posted by alpaccino
![Confused](https://fordfestiva.com/forums/core/images/smilies//confused.gif)
I made 1.250" o.d. bushings for the lower holes out of steel round stock. I did this because I set the strut body up in a mill and indicated off the top hole, I then used a 1.250 end mill to plunge holes in the proper spacing to fit a festiva/aspire/capri/rio/323 ect ect spindle. I then elongated the upper hole to allow for camber adjustment. Then I bolted the strut body to a knuckle, and bolted the bushings to the knuckle as well and welded the bushings to the strut body. This makes the VW strut fit the Mazda/ford bolt center properly and allows for lots of camber adjustment. I'll try to find more pictures of the process, sorry if it's confusing. It was just my way to make those lower strut mount holes line up the properly. I tend to overbuild things, but I'm not easy on equipment so it pays off in the long run.
![](http://i1094.photobucket.com/albums/i443/advancedynamix/Snapbucket/ff33a4f5-eb7f-4697-b764-b1ccafb68ce0.jpg)
Here you can see how there is a bushing welded in to fill in the 1.250 holes that were plunged through the bracket. I did this to drill out the stock hole entirely since the hole was in the wrong location for a festiva. I think other people have just opened up the holes a bit to accomplish the same thing. I am extremely hard on my suspension, so I wanted to add strength to this area. I check the welds regularly and haven't noticed any indications of fatigue.
