I need to add a spacer to my rear wheels for clearance. I was thinking of just order new shanks instead of converting to studs/lugs.
If I do, would these do the trick? http://tinyurl.com/c3nhtxz
I measured stock shanks to be about 20 mm. Therefore, if I am going to use a 5-10 mm slip on spacer, these would be more than adequate. Makes sense right?
I also wanted to confirm that the wheel center bore was 54.1 mm. I've found a few different sizes while searching.
