I don't know about 10" per se... but the FC/FD 4-pots (the same, just different appearance) will work with 276mm rotors as well, which is 10.8". Damkid and I are working up a set of FC aluminum calipers using the 276mm/10.8" rotors... which I acquired from the first generation Mini Cooper S. Stay tuned for updates on that one when DK gets some free time! AFAIK, the 294mm ones are all second generation Cooper S's, as well as the Works Cooper.
custom 11.5" dual piston brakes
I thought you can bolt on get escort calipers, but not escort rotors exactly?Originally posted by FestYboy View Postkarl you can get a 10" brake... escort or capri depending on your lug pattern.rusEfi - DIY ECU
93 EFI: tach cluster, aspire mirrors & spindles. ZX2 master cylinder, BP+G25 swap with a door hinge, rio struts. 205/50r15, 140mph speedometer,rear disk brakes, mini cooper + subaru front brakes rear sway bar
My mazda 2 has aluminum calipers... perhaps some are available somewhere to check out?89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
I have tried to fit FC RX7 calipers onto a Festiva with capri brakes and it was a no go with my 15" o.z. wheels, but may work with my Enkeis and some spacers. The problem with the RX7 calipers is that they are just too bulky to fit behind the wheel with the amount of available fender room under a festiva.
The BF 323 crowd and Capri guys run some sort of 11.5" galant rotor iirc and an escort GT caliper iirc for huge front brakes. They then run a 1 year only 626 M/C that has a 1" piston. My friend has this setup on his GTX, I'll try to get pictures the next time I'm there.
Sorry for the sideways picture, not sure why it did that. the Capri brakes fill a 15" wheel pretty well, and don't weigh much more than a stock festiva brake setup. There are several members who have done this swap, it's easy. Not really any performance gain over an Aspire setup.Last edited by Advancedynamix; 08-07-2012, 07:47 PM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
I'm not looking for breaking gains so much as I'm looking to reduce unsprung weight.
I think the 9.5" diameter rotor with my current auto Aspire setup does well.
I could go for another .5" of rotor diameter, or I could go for the same auto Aspire 9.5" rotor with aluminum calipers, as long as they worked and lasted as well as iron ones.
I'd also prefer to mount this setup on '02 Rio knuckles because they are newer and would have less beating on them (from a lower miles car anyway).
As I said, with escort/aspire short&wide style of pad there is no way to _mount_ anything, you are talking welding here. As soon as you are talking welding - you are probably talking changing the fried bearings, so at this point spindle age does not matter much.Originally posted by Safety Guy View Post...I'd also prefer to mount...
With 03+ style kia spindle, chances of mounting some nicer caliper without custom welding are going up. Now it's just a question of finding a caliper which would mount either with stock 03+ mount or some kind of bracket.Last edited by russian; 08-08-2012, 10:39 AM.rusEfi - DIY ECU
We did it! The brakes worked great! while Wagner brake rotors have warped out right away, we had a LOT of stopping power! And, most importantly, the calipers stayed where they shouldOriginally posted by jemartin144 View PostWow, crapcans at Road America; that should be interesting. Lots of straights for people to blow engines up on and have brakes fail at the end of. Good luck. I wish it wasn't on a monday-tuesday, so I could come watch.
rusEfi - DIY ECU
wagner products are junk and most places who sell them stack the rotors on edge (this is a big no-no). find some heavier OEM rotors to use (like from BMW) and you'll note that they don't warp (more thermal mass)Trees aren't kind to me...
Apparently they have 316mm / 12.4" rotors in some newer minis! But what would probably mean either more spacers or 16" wheels...rusEfi - DIY ECU
The car was a blast to drive! Unfortunately there were too many little stupid failures - custom fan housing rubbed a hole in the radiator, this cost us 20 minutes. Probably because of coolant in the intake the MAF has failed two hours later - another 20 minutes... Inertia switch killed the car at some point - another 10 minutes to fix... And the rear trans mount failed 40 minutes before finishOriginally posted by jemartin144 View PostCongrats! How did you guys do at the race?
Still, we finished #22nd (with 51 cars running), and that's on a HP track! We hope to do much better at Autobahn in October
rusEfi - DIY ECU
As for 4 piston RX7 calipers, we are now trying to put them on an Escort GT... And looks like it would be even easier - we are reusing one of the mounting holes, only welding a bracket for the second hole... Will post pictures eventually
rusEfi - DIY ECU
Russian what kind of pads are you using? that should be PLENTY of brake for what you have to use,
My theory behind braking is brake compound should correlate to tire compound, with azenis you shouldnt need more then a hawk blue.
when the miata ran ra1's i used hawk blue's and they were good, when the miata used slicks i used upgraded hardware with dtc60's. They lasted at least a weekend but thats using 13x8" hoosiers and alot more power.
We are using carbotech xp8 - after one race we did not notice any wear. The idea is to save $$$ by keeping them for a while.Originally posted by festyfreak39 View PostRussian what kind of pads are you using?rusEfi - DIY ECU
