Originally posted by gestiva
custom lift
That almost works, the geometry as viewed from the front has a slight A shape. As the lower part goes down it needs to get wider. As viewed from the side the lower is in general in front of the top part. As the lower part goes down it needs to shift to the front. With these two things it can be aligned.Reflex paint by Langeman...Lifted...Tow Rig
Being an offroad guy, I actually like the idea if done correctly. Offroad to me doesn't mean beat the living crap out of it till it breaks. Well, I do do that on my dirtbike.
Here's a Festiva done up like you want to do.
How about a Beetle and a Golf?
DSC03747.jpgAttached FilesLast edited by Eaglefreek; 01-10-2013, 09:56 AM.Rick
1993 Ford Festiva
1986 AMC Eagle Wagon 4.2L/4.0L head, AW4,NP242, Chrysler 8.25" rear. SOLD
1981 AMC Eagle Wagon-As Seen on TV Lost In Transmission
2000 Ford E350
That is cool, cars that can go awhile without refuel yet not leave you
walking cause they are stuck!
The festiva is not lifted but baja a bit. He also has desert tires in the sand
with wayyy too much air, didn't work to well.Reflex paint by Langeman...Lifted...Tow Rig
That Golf was done really well. Gross on the new Beetle! Love old Baja Beetles though!
okay i got my lift done in the back only took me a day to do and i got 6inches of lift on the rear gives me about 13inches of clarence with stock festiva rims and tires!! now i got to do the frount i already have it built and ready to be bulted on but the axles are to short and ford aspire axles are too short too. so i got to make cuztom ones. any idea how much longer to make the axle shafts? also the control arms and sway bar mounts have to be ajusted too? any tips cuz this is new for me with this big of a lift on somthing never ment to be lifted..
so basically i need to make longer axles, custom control arms, longer tie rods, and alter the sway bar mount. so if any one has ever done this it would be nice to get a tip1993 festy "white stallion" BP swap with 7" lift, 1ton wench
R.I.P. 1991 festy "the festiva" stock b3, atv bumper, 8' whip
As mentioned in a previous post, a member here named "Movin" ( from post #18 ) has the info you need.
He has ATV tires on his lifted Festy, and modified suspension components. PM him.
He also has cool pics on his profile.Last edited by drddan; 05-03-2013, 06:46 PM.Dan
he hasent lifted his like mine he only swaped out ford aspire suspenshion thats all nothing near as extream as i am doing he only did a 2 inch lift im doing 3x that much1993 festy "white stallion" BP swap with 7" lift, 1ton wench
my bad i thought someone told me you did and sence thats the case what did you have to change on the frount end of the car to get that lift to fit with out it pulling the frount axles out cuz when i tried to bolt in my lift for the frount it pulled them out cuz there are too short1993 festy "white stallion" BP swap with 7" lift, 1ton wench
Chris...I tried to tell youOriginally posted by Movin View PostCurrently I have 6 inches from original in the front and 7 in the rear.
.... this guy knows what he's doin'!!!! Movin' Marvin...FTW! lol
I dont know who's got the most modified Festy's .... Movin' or Advanvancedynamics. 'Course they went in different directions!
Advanced has his modded for Auto-x and Movin' for Off RoadinLast edited by drddan; 05-07-2013, 01:31 PM.Dan
i got an all stock one to besides the steal bumper i made so the weight is all the same thow plus the winch im putting on to so mine will be heavy!! and i dont want to over do any one or do i?? :laughing3:1993 festy "white stallion" BP swap with 7" lift, 1ton wench
