Aspire Swap Question
  • Aspire Swap Question
    What is the difference between doing an aspire brake swap w/ the aspire swing arm and keeping the stock?
    91' Festiva GL Auto EFI--- BP swapped, G-Series swap in the works.
    Adjustable VW MK2 front suspension and Aspire disc brakes
    Aspire rear axle and drum swapped with adjustable KYB rear suspension
    LOOKING FOR RUST FREE SHELL IN CALIFORNIA
    Bolt circle. Brakes are a little bigger. Stiffer arm.
    Rodney
    1991 FI 5 Speed Aqua Blue
      Spindle bolt holes are slightly different. Rear Aspire beam has built in rod to stiffen it more.
      Jerry
      Team Lightning
      Owner of Team Lightning
      93 L Lightning. BP
        But it can be done w/o it right?
          Done without what part?
          Jerry
          Team Lightning
          93 L Lightning. BP
            By swing arm do you mean the sway bar, the lower control arm, or the u-shaped tortion beam trailing arms?
            -Zack
              My bad, i shoulda been more clear about that. i mean the rear axle beam/sway bar
                I've done or helped on 3 swaps. In my opinion, It's better to change the rear beam. 1. it's a newer part, 2. It's stiffer and handles better plus it's set up to work with the front ASpire suspension. 3. Then you don't have to drill out the spindle bolt holes on your Fesiva beam. I even put the 5/8" rod in my Aspire beam. I like the way it handles now. My silver 90L has 97 auto Aspire suspension. My 93L has 97 Aspire Manual suspension. I'm sure there's other opinions about what i've done to mine but, I like the handling of it and I"ve been driving it (90L) for 22.5 yrs. It now handles and stops like it should have from the factory.
                Jerry
                Team Lightning
                93 L Lightning. BP
                  To me, availabilty is a problem. If I want to use 4x100 wheels, then can I aspire swap the front end, and somehow setup the stock festiva rear to match the lug pattern?
                    I have the same problem. I looked up info on the 90s Honda Civics, and from what I can tell(which is not much yet) you might be able to use manual trans rear floating drums, shoes, and the bearing/hub assembly all from the Civic with the stock Festiva rear end. To be clear I have NOT done anything in the real world with this idea. Just webernet searches.
                    Here's what I found
                    Stock Festiva inner wheel bearing race inner diameter and Civic cartridge bearing inner diameter are VERY close as follows:
                    Civic inner diameter 27.5mm
                    Festiva inner diameter 27.3mm
                    Stock Festiva rear drums and manual trans Civic rear drums are VERY close as follows:
                    Civic inner diameter 180mm
                    Festiva inner diameter 170mm
                    And of course the Civic is 4x100. My thinking is that if you could take a stock Festiva rear end and mate the Civic bearing/hub to it (which on the surface seems very possible to me) you cold drop on the Civic drums and use Civic shoes to complete the package.
                    Again, no real world measurements there, but I will try it eventually if no one disproves it first.
                      You can get dual pattern wheels, use rio front spindles and the stock Festiva rear beam.
                      Jerry
                      Team Lightning
                      93 L Lightning. BP
                        That's what I was going to say. I did the Aspire swap (front and rear) but my wheels are dual bolt pattern.
                          Now which Tie rod ends should i use for the outter and inner?
                            and which brand should i use Wagner or Wearever Parts?
                              nevermind on the brands.
