Mazda 2 stabilizer bar bushings.
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
Tags: None
'92 Festiva L M/T
'93 Festiva GL A/T
You have to lock them into place due to the slotted holes. A large washer might work on each slot. If it moves it can change your alignment.
I sanded mine to fit the Aspire brackets on my sway bar.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
WHY DO PEOPLE STRESS ABOUT THIS ??? Euro an me run this style and he has autocrossed his car and drag raced his car VERY HARD!!!!! RUN A ALUMINUM PLATE UNDER THE BRACKET DRILL TWO HOLES AND TIGHTEN UP DONE!
Sorry but this has been beaten to death. Like 2742826788626171 times it works for me and Greg and we don't drive our cars with a purse on our shoulder!!! Rant off.
BINGO! good idea m3ntal;
'92 Festiva L M/T
'93 Festiva GL A/T
Which bracket do you use then? aspire/festy, or the one that comes with the kit? Also, how thick of plate?Originally posted by M3NTAL View PostWHY DO PEOPLE STRESS ABOUT THIS ??? Euro an me run this style and he has autocrossed his car and drag raced his car VERY HARD!!!!! RUN A ALUMINUM PLATE UNDER THE BRACKET DRILL TWO HOLES AND TIGHTEN UP DONE!
Sorry but this has been beaten to death. Like 2742826788626171 times it works for me and Greg and we don't drive our cars with a purse on our shoulder!!! Rant off.Last edited by 91blufestiva; 03-28-2013, 02:39 PM.-Josh R
The little 1/8 inch aluminum or metal plates anyone here wants , are simply 2 inches by 4 inches exactly with 2, 1/4 inch holes at each end. you can remove one sway bar bracket and trace it on some scrap metal and with a hack saw and one drill bit your done. A band saw and a drill press makes it even easier
! then you can get the generic 18$ or whatever grease-able ENergy SUS bushings and.......................... ENJOY
RJ
Use the ones that itcome with the bushings they will not slide with the aluminum under them.i have had this set up for 10,000 miles with hard driving.
And trust me i was sceptical when i first did this after reading it worked on here.
But they are great.
