17's?
  • 17's?
    I seen some 17" 4 bolt wheels with 205/50 yokohama tires for $375 on CL, so I'm wondering
    what would it take to shove these under a festiva? hmmmmmm
    Not sure but someone posted this photo a while back. I'm guessing it has 18's.
    Jerry
    Team Lightning
    Owner of Team Lightning
    93 L Lightning. BP
      Those tires look fun to mount, but I guess with extra low profile they're close enough to not need mods.
        Both of my cars have been changed to studs instead of the bolts from the factory. It make putting the wheels on a lot easier. Plus I'm running 14's on one car and 15's on the other one.
        Jerry
        Team Lightning
        93 L Lightning. BP
          Oh...it will need mods to fit 17's! Anything over 15" gets tricky to get them to fit without rubbing somewhere. The shocks in the rear are a limiter. Spacers required to clear the spring perch on the strut. Front wants to hit stuff when turning. Minor stuff really, but some mods are required.
          Check out this tire size comparison site:
          That size 17 is 3.3 inches bigger in diameter....and 2" wider than a stock tire
          Dan
            Anything is possible with a big enough hammer :highly_amused:
            Barbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
              17" wheels could be cool with some work. 195/40s, coilovers/air ride and a lot of cutting.
              205/50 is an absurd tire size for a 17" wheel on a Festiva.
                i posted it and they were 20's with custom suspension you are unable to drive over 30 mph with those rims.
                www.facebook.com/rhodestiva ;
                rhodestiva@gmail.com ;
                '92 Festiva L M/T
                '93 Festiva GL A/T
                  the guy work at a auto place in milton fl you could call and ask him i dont know the number though.
                  '92 Festiva L M/T
                  '93 Festiva GL A/T
                    These are the biggest wheels I've seen look "right" on a Festy. Not sure what size they are, but they took a LOT of work to look like they should be there.
