so on my passenger side i have some stripped bolt holes and can't rethread them. Has any one installed studs on these before?
2001 kia rio stripped lug holes
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
Tags: None
You could probably try some Chrysler minivan studs, they press in from the backside and have the same thread pitch as Festy bolts, but the base seems wider than the shaft.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
yea. i was wondering if you could get some in from the back side. i will go buy some studs and try it on the one wheel. and take lots of pictures.;
'92 Festiva L M/T
'93 Festiva GL A/T
thinking about doing the civic extended studs for my rims.;
'92 Festiva L M/T
'93 Festiva GL A/T
I have installed studs in stock Festiva hubs, and aspire hubs. You will need to pull the hub out of the bearing in order to get it pulled through. You will also need to drill out the hole to the proper size for the wheel stud your going to use. Honda studs use a huge hole. I work at a Toyota dealership, so I have access to virtually unlimited free wheels studs if I'm willing to wait for a hub bearing to be replaced. The Toyota studs are a good size and length, same thread pitch as Mazda uses. When looking up the studs at the parts desk look them up for a 05 corolla. I don't remember the exact drill bit size needed, I have it written down at work in my tool box, but it will be Tuesday before I can get back to it. I did this job for Spike on his auto car. Turned out very well.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
Very well, indeed! If I hadn't had a drum failure, I'd still have all 16 studs holding strong.Originally posted by gauge_half_inch View PostI did this job for Spike on his auto car. Turned out very well.
Now only 12 lol (only because I never got around to redrilling and studding).
-JoeLast edited by Spike; 05-24-2013, 06:26 PM.White '92 GL 5-speed BP, G series, Aspire/Rio swapped, "Nancy"
1988 LX 5-speed
1993 L 5-speed B8, E series, Aspire/Rio swapped
Gone:
Stock capri studs are Dorman 610-294
5mm longer studs, same pitch that fit in the same shoulder are Dorman 610-340
Interested to see the results, Kia hubs are available brand new1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
'92 Festiva L M/T
'93 Festiva GL A/T
